Ethernet for sPOD wiring help?
fieldgeneral
North Carolina
Has anyone installed an sPOD and run the control wire (ethernet) into the cab?
I have the spod already in the engine bay and am committed to it so not looking for alternatives. Went to run the ethernet today and the factory pass through grommet on the driver side, which comes out under the steering wheel in the cab - seems like the hole on the interior side is too small to get a RJ45 connector through it. Due to the location you can't really enlarge the hole either.
Wondering if anyone has successfully installed this setup, and if so how did you run the ethernet wire into the cab?
