Emblem removal and painting
Can you post a photo when you put them on? Still trying to decide on those.
The lighting is somewhat deceiving - the gray appears lighter than it actually is. Swapping them out took 5 minutes.
Wow those look great! Thanks for the photos. Nice job. I think that black surround would look good against my black paint.
If you don't want to save the old emblems, just snip the rear clips. I was debating of buying the special tool to remove the clips, but I had no intention of reusing them.
Another question: is the whole thing a different color or just the rectangular part that says 6.6L Allison etc?
I can get another picture in better light if you want.
I think I got it. From your other pic though it did not look like there was a huge difference. I would be fine with simply replacing the rectangular insert rather than the entire thing.
Here is a picture that isn't light saturated. The outside is gloss black; the inside is a dark gray with black lettering.
If you don't want to save the old emblem do you have firewall or can you just a flat screwdriver or something from the outside?
I used a heat gun until emblem got hot enough to tolerate by touch then wedged a plastic razor blade to raise one side until I could grab it with fingers. Then slowly pulled so that it removed with adhesive.
Recommend placing blue tape around the edges to protect from slipping.
Nice! Looks great. I sprayed hyper dip on all emblems to "Delete" the chrome when i first got the truck about 2 years ago and it has held up well.
I didn't save my old badges. There are 4 or 5 clips that hold on the badge. A screw driver will work - I used pliers and snipped the clips and the badge pulled right out. Just pop the hood, pull back the rubber and the clips are accessible. It took 5 minutes to remove and install the new badging.
Are you asking if the badging is hindered by the firewall? No.
