Burning oil?
JimP
San Antonio
Military
Retired Army
2024 AT4, 3.0 liter Diesel LZ0. 38,000 miles. Just realized that I burned a quart of oil traveling from the north east back to Texas. Towing a 19 foot Airstream with maybe 5-600 pounds in the bed of the truck. In all honesty, probably put three thousand miles on it with all the camping, side trips, etc.
I don't think a quart in 3K is too much but it never burned a drop of oil up to this point.
Issue?
Go under and look for leaks. It's also possible that the dealer, like for many others, failed to inject the proper amount of oil. Unless you do your own oil changes and can vouch for the exact amount that went in, then the dealer probably what happened.
I do my own oil changes as I use a PPE filter and change a bit early since the oil is so thin. No leaks, and I am sure I had the right amount of oil as I check it often.
In that case - probably normal operation. There's a bulletin and several articles online if you look it up
