Thx1158
The only issue I've had with my Dash has been with the updates. I doesn't seem to want to update easily. No big deal as I can skip it and keep going but it is very annoying.
Very Interesting; please share more info. For the little driving I currently do, I've not concerned myself with regen or anything, so long as no codes pop up and the truck and its electronics behave perfectly, including mods I built from scratch.I considered the Banks. Lot of money for me to essentially monitor regen. I landed with the VeePeak OBDCheck. A simple plug in device to the OBD port, connects via Bluetooth to phone, and integrates well with Android Auto and Carplay (or whatever the Apple version - I use Android) so you can see info on the Infotainment screen. The device creates data logs for an export to Excel. Bought the Fusion app for $6 and the device for $40. I can move this device from vehicle to vehicle if needed. Very happy with this solution.
2020 GMC babymax
Mostly commuting
Very little towing
Thank you but I have one on the way.....The super guage will show you all of this. I just recently got an idash (wanted the bluetooth) and have a super gauge sitting on the workbench unused.. if you're interested
Had some free time tonight and made the mistake of attempting to update mine (dual pod setup). Apparently, due to firmware issues the new update will not propagate to the secondary iDash module through the jumper wire. So after the first update, I received an error prompt telling me that I need to remove the jumper wire and plug the primary cable into the secondary gauge in order to perform the update, after which everything should function as it should. In the interim, both gauges still function, but the app will no longer connect to the secondary gauge at all.The only issue I've had with my Dash has been with the updates. I doesn't seem to want to update easily. No big deal as I can skip it and keep going but it is very annoying.
So I actually just did mine less than an hour ago before seeing this and same scenario needing to move the jumper wire and I have dual pods as well.Had some free time tonight and made the mistake of attempting to update mine (dual pod setup). Apparently, due to firmware issues the new update will not propagate to the secondary iDash module through the jumper wire. So after the first update, I received an error prompt telling me that I need to remove the jumper wire and plug the primary cable into the secondary gauge in order to perform the update, after which everything should function as it should. In the interim, both gauges still function, but the app will no longer connect to the secondary gauge at all.
So I now have a multi-hour project ahead of me of pulling those gauges back out of the A pillar and swapping the wiring around. There are worse things in life, but it would have been nice to know the update was going to cause this issue BEFORE I installed it. Be forewarned if you have a multi-gauge setup that you haven’t updated in a while.
