You can tap a wire leaving the lighting control module under the dash but it is very small gauge so should be for trigger signal only. I did the same for my cubes in the aftermarket bumper I installed but used SAE rated bright pattern to stay legal. You can find the circuit and location for your specific truck here:
https://www.gmupfitter.com/
Also I’ll just point out that auxiliary lighting that spills past the extent of the factory brights may be illegal for on road use in your jurisdiction, do with this information what
Also I’ll just point out that auxiliary lighting that spills past the extent of the factory brights may be illegal for on road use in your jurisdiction, do with this information what you will.
One thing that is nice on the Garmin switch is with a click of a button on the app, you can deselect the trigger that powers a circuit. You can turn on or off the function of having the lights work with the brights, on not. 99% of the time the lights wouldn’t be activated by the brights. When I am hunting coyotes on the backroads in the middle of the night, they would be.
