AT4 Puddle Lights Customization
Finding OEM puddle lights too monotonous, I customized their designs. Many friends have helped us throughout this process - we're truly delighted you all like them!
After five rounds of customization tests, our service now supports any pattern design. The only current limitation is that we can only offer black and white colors for now.
Is it possible to order the Bills mafia one if I do not have the image?
Do you have an eta on the new brighter at4 lights yet ?
We have been doing research and development, but the cavity always fails due to overheating, and the yield rate is too low. We are working hard to achieve breakthroughs in new structures. Now the heating problem of the basic version has been solved, and the problem of the high-brightness version is being solved.
Mixander can you check on invoice 3579 for Christopher Scott Combs.
Third set came in, for what ever issues I might have had the seller is on it with replacing them.
Fit perfect, and brightness seems to be a tad more. I'll say other people really notice these things at night. I can't remember how many "Wow" I've heard in a parking lot at night.
Fingers crossed these will last.
Do you have a picture of what they look like at night? Thank you.
Picture in the driveway with a bunch of lights on I’ll get a better pic later
I’m having a problem where my custom puddle lights are constantly turning. I adjust them and get them lined up, and the next time I see them, the lights are all out of whack.
Just a bit or completely turned? How old is the set? My very first set was so loose that they often did the same, not the white bezel but the whole fixture could move. I would come out a t night and see it was not on the ground where it was suppose to be shining and reach up to turn it and the unit would pop back into place without needed to turn anything.
I made a video to show the seller and he sent a replacement set.
It doesn't seem like the whole fixture is moving - it is in there tight. I just have to constantly turn the white bezel to adjust the light - it will be turned up to 180 degrees sometimes.
All three sets I've had you practically have to use pliers to get them to turn, message the owner here and see if he will warranty them.
If it was me I would set them to where you want them and then maybe make a notch with a knife so its locked at that position.
I was thinking a drop of crazy glue. 😁
