Airhorn Installation - Thoughts
i got the 5g spare tire delete
supposed to have it installed next Wednesday
i'll let you know how i like it
I have a Hornblaster setup off my old truck that I want to install here on my GMC 1500 AT4. Cant wait to see a few set-ups!!
I was looking at the Hornblaster Spare tire delete kit also. I spoke to a "dealer" and they were talking about $2800 to have one installed. On the hornblaster site it kit was about $1400. Not looking to pay $1400+ in labor 🤦🏿‍♂️
Yikes!!! Yeah that's a lot........
How many horns do you want? You can install a single/double horn setup without the tire delete. The sound isn’t as loud but it is a lot louder than stock. I have a single horn installed behind my grill. Took about an hour once I found a spot. It has a much smaller air compressor so there are more install locations. Draw about 16-18amps so easy to add a relay or wire to a gang switch.
Im wanting at least 4 horns. I have started to look at that the setup with the smaller compressors also.
Has anyone installed a airhorn on their truck if so which did you go with and why?
Im looking to potentially purchase a spare tire delete airhorn system.
Good evening, I installed the Hornblasters Conductor Special 232 on my 24 2500 HD. I installed them behind the grill. (Sorry no pics, got deleted off phone, but they might be on here on another post I responded to). I bought a metal bracket from HD that already had the holes in it, and made 2 brackets to mount the horns to. I put the compressor in the empty 2nd battery tray (perfect fit). Bought an Auxbeam upfitter switch so I can switch the compressor on and off. I bought a 200psi 7 gal tank off Amazon for $80 along with air line tubing. I mounted the tank in the bed. Then bought 14 gauge wire from the Marine store to run the wires. This is my 3rd set from Hornblasters, my best set up to date and the loudest. Only had to call customer service once. They were more than helpful, responsive, and quick to get the part out. Call me if you have any questions. Tom
