2024+ Sierra HD Owners: 40" PRO Grille Bar That Also Works With AEV Bumpers
Burbank, CA
This 40" PRO bar is made for the 2024 to 2026 Sierra 2500 and 3500 HD in PRO, SLE, SLT, AT4, Denali and Ultimate trims, and it also works with AEV bumpers. It stays slim to the grille and does not interfere with the active grille shutters. The bar only covers a small part of the grille opening, so the mesh around it stays open for full airflow. The PRO bar runs a combo pattern for distance and width, plus an amber DRL backglow.
  • Fits 2024-2026 GMC Sierra 2500/3500 HD (PRO, SLE, SLT, AT4, Denali, and Ultimate)
  • Also works with AEV bumpers
  • Complete bolt-on kit that uses the factory openings and hardware, no cutting or drilling
  • Choose white or yellow
Here's the 40" PRO output:
mr-automotive-2024-gmc-sierra-2500-3500hd-40in-light-b-8.webp mr-automotive-2024-gmc-sierra-2500-3500hd-40in-light-b-11.webp
Forum members get 10% off with code AT4Forum at checkout.
2024+ GMC Sierra 2500/3500HD 40in PRO Light Bar
Check the two frame horn mounting bolts behind the bumper—those see all the bar's vibration and tend to loosen, so hit them with medium threadlocker and torque to spec. Also inspect the ground strap at the chassis horn; a corroded eyelet causes flickering DRL backglow that looks like a bad bar. Dial in the light aim after install so oncoming traffic isn't blinded.
