Has anyone replaced the drivers side weather stripping on a AT4X? Mine has a tear where the previous owners foot must have continually hit it. I know the trim on the edge just pops off but was curious about higher up on the dash.
Check the A-pillar grab handle and kick panel first—those pop off with a trim tool to expose the weatherstrip channel. The upper dash section usually just needs the door seal pulled back, not full dash removal. Look for the seam where it tucks behind the dash edge. Also inspect the door hinge area for bent pinch weld from that foot contact, since a torn seal often means the door was slightly misaligned.
