Weird issue after installing Pulsar LT
cbdAT4
Georgia
Curious if anyone else has experienced the issue I’m having… I waited for a while after the pulsar was released in hopes all the bugs would be fixed…. I have a fully loaded, minus carbon pro, 2019 6.2L AT4 and installed the Pulsar LT today…. Easy install and programming features…. Everything appears to be working to my selections but once I start driving my drivers side blind spot warning light comes on and stays on…. It will turn off when I make turns but back on when I straighten out…. Sometimes it flashes quickly…. No other lights on dashboard or anything else weird, just the blind spot warning light on drivers side…. I’ll be calling tech support but curious if anyone else has experienced this?
From what I've read the Pulsar has a lot more options but I've ran the Pedal Commander in my last 3 rigs and it's simple and works great but it doesn't do everything the Pulsar will. I will say the PC makes the 6.2L a whole different experience when you need to go.
This has happened to me...and I don't have the Pulstar. Mine happened just like that when it was raining. No explanation, but I wouldn't blame the Pulstar just yet.
I agree, I had my radio would not turn off with the button or when I would shut the truck off and open the door it would finally turn off after a while. Then the next day the screen lit up with a message and GM did a remote update that I had to leave the truck running it took about 15-20 minutes and then everything was back to normal. No Pulsar but that might be coming your way soon.
I have the same problem cbdAT4: , and I was wondering if you found a solution. Please let me know I need my blind spot working.
Have you updated the Pulsar LT recently by chance?
Any luck with tech support. My 21 trail boss is doing the same thing. Just installed it 3 days ago. Annoying to say the least
I had the same issue with my 21 AT4 and Pulsar but just lived with it for 2 yrs. Was random but did seem to occur more when raining. Not sure there's a fix.
