What's the largest tire that fits on the stock AT4 HD wheel without rubbing?
I ran those on my AT4X. Thinking of going the same on my AT4 HD.Anyone running a 295/65r20?
Thanks285/65 r20 (35x11.5x20) Nitto exo grapplers will not rub crossing ditches at an angle.
Welcome.Hi all, first time poster and happy to be here. Just took delivery of a 2025 AT4 HD and would like to swap out factory tires for a 295/65/20. Has anybody done this as I do not want to modify factory suspension. Would like to go with the Nitto Ridge Grapplers and hoping for no rubbing. Thanks in advance for any info.
Nobody makes the same size tire. But to answer your question I’m running Mickey Thompson Baja legend EXP 295/65/20=35.4” X 11.6”(MT stated dimension) no rubbing or trimming stock AT4 HD wheels at factory height.Hi all, first time poster and happy to be here. Just took delivery of a 2025 AT4 HD and would like to swap out factory tires for a 295/65/20. Has anybody done this as I do not want to modify factory suspension. Would like to go with the Nitto Ridge Grapplers and hoping for no rubbing. Thanks in advance for any info.
WelcomeHi all, first time poster and happy to be here. Just took delivery of a 2025 AT4 HD and would like to swap out factory tires for a 295/65/20. Has anybody done this as I do not want to modify factory suspension. Would like to go with the Nitto Ridge Grapplers and hoping for no rubbing. Thanks in advance for any info.
Appreciate the info. Had Goodyear Duratrac 305/55/20 on a 2015 Silverado HD and heard the space in the wheel well of the newer truck had more room. Not sure if this is true but was wanting to try 295/65/20 on this one.Nobody makes the same size tire. But to answer your question I’m running Mickey Thompson Baja legend EXP 295/65/20=35.4” X 11.6”(MT stated dimension) no rubbing or trimming stock AT4 HD wheels at factory height.
Ridge grappler 295/65/20= 35.1” X 11.77
I don’t see an issue with 0.17” wider.
Should be fine just look at each tire mfr specifications. You’d also be surprised at weight differences.Appreciate the info. Had Goodyear Duratrac 305/55/20 on a 2015 Silverado HD and heard the space in the wheel well of the newer truck had more room. Not sure if this is true but was wanting to try 295/65/20 on this one.
