Upfitter Switches.
There are none for the refreshed at4hd and above trim.
404 parts has a kit, but does not include a knee bolster or dash molding. Haven't seen any installed, but you have to cut into your plastics to install.
I saw that one. I guess they would go to the right of the steering column. Fuse panel to the left.
Can you send a link? I'd like to know what the install is like. Not worried as much about the mounting location but the wiring. From descriptions of the other setups I've read there are connectors behind the dash to plug into but if they dont offer a switch panel for the newer trucks do they even have that connector as part of the whole wiring harness?
Here is the link to 404 Parts;
And here is the GM TSB showing how to put them in; https://www.gmupfitter.com/technica...m_technical_bulletin_vehicle=Silverado/Sierra
Looks like gm is making a lower dash bolster that won't be available till 2025 or redesigning the dash again for 2025 and leaving the 2024 behind...
And here is the GM TSB showing how to put them in; https://www.gmupfitter.com/technical-bulletins/?_sfm_technical_bulletin_year=2024&_sfm_technical_bulletin_vehicle=Silverado/Sierra
Thank you. Here is a cut and paste:
I am watching very carefully for any 2025 changes but I took it differently. I just thought the wiring provisions may not be in 24 but plan to be in 25.
gm is saying something about the '25 ushering in something, including new powertrains. Online, I have heard squawking of a 507 duramax (8.3l for you metric folk).
So, yeah, I'm watching closely also @Viking Truck!
I guess, what I'm referring to, is the line of... TBD for the engine and tranny.
I suspect this type of speculation goes on every year. It sure does in the Jeep world.
