Tries rub on frame
Andrew10
Lt1-3ssd
Just purchased my vehicle 2020 gmc sierra 1500 at4, and it came with LT295/65R20 tires. These aren’t stock tires. Problem I’m seeing is that when making sharp turns, tires rub on the frame of the vehicle. What would be the best option to go about this, would I have to upgrade the suspension on the truck so that I can run the same tires without any issues. Or downsize on the tires?
Id say you need a negative offset wheel to make those tires work. But with negative offset you me end with rubbing on your wheel wells that you may have to trim unless you do a lift or level which may still require trimming . Most cost effective option will probably be smaller tires
