Trailering Capacity 2023 2500 AT Reduced by 6500 lbs
Strange. Mine, with 20" Goodyear tires is rated at 18500#.
Where did you see the 12000# capacity? On your door jamb?
Yes Sir on the door jam. I was looking at a Black one and a white one, identical in every way until I spend the door and said to my salesman what's up with this. Michelin. vs Hanook??? Hanook is more expensive on tire rack, both same weight rating Class tires,
What was his answer? Without knowing the tire specs, I can't look up the rate rating of them. But 6000# is alot!!!
His answer is 6500 difference. I thought I was lucky just to find a new 2500 truck at a GM dealer. The two trucks they had in stock both had 18" wheels, 275 70 18's. I was happy with 18s for replacement cost alone and having to buy snow tires in winter for plowing snow. Dealer was puzzled, no ever asked the question or noticed. On GMC build site they only offer 2 tires. I even went to Tirerack and asked them, both class E tires, both with same Load range only difference was speed rating one was S the other was R. Since I seldom travel at over a 100mph speed rating shouldn't matter. Ha. Stupid.
His response is hilarious. But from what I have seen, that sounds like what kind of sales people we have here.
I am certainly not trying to say you are incorrect, I am just surprised. I can't seem to find a 2023 GMC Trailering Guide online, but I do find a 2021 which of course is the same body style.
I can only see that the lowest trailering capacity for a 2500HD is 14,500.
Build & Price: 2023 Sierra 2500 HD
CREW CAB, STANDARD BED, AT4, 4WD
SAVED (1)
CONFIGURATION
TRIMS
EXTERIOR
WHEELS
INTERIOR
PACKAGES
OPTIONS
SUMMARY
Exterior
Exterior
WHEELS (6)
18 machined aluminum wheels with Dark Grey metallic accents
18" machined aluminum wheels with Dark Grey metallic accents
Standard
gmc
Wheels, 20" transit aluminum wheels
20 machined aluminum wheels with high gloss Black accents
20" machined aluminum wheels with high gloss Black accents
$800
20 High gloss Black painted wheels
20" High gloss Black painted wheels
$2,995
20 high gloss Black aluminum wheels with machined accents
20" high gloss Black aluminum wheels with machined accents
$2,995
20 machined aluminum bolt pattern with high gloss Black accent wheels
20" machined aluminum bolt pattern with high gloss Black accent wheels
$3,295
TIRES (3)
gmc
18" LT275/70R18E all-terrain, blackwall tires
gmc
20" LT275/65R20 all-terrain, blackwall tires
gmc
18" LT275/70R18 mud-terrain, blackwall tires
$295
Message Us
vehicle configuration
More Views
Net Price $78,680†
SUMMARY
NEXT: INTERIOR
Try this go to GMC website and do a build with the 18" tires. Notice the little I in the circle
$295
Due to current supply-chain shortages, certain features shown have limited or late availability, or are no longer available. See the window label or dealer regarding the features on an individual vehicle. Preproduction model may be shown throughout this experience. Actual production model may vary.
  • Aggressive tread may result in a higher level of noise while driving
  • Routine tire rotations are highly recommended
  • Note: This tire has a reduction in conventional trailering capacity. See dealer for details
Se dealer for details. Ha so I asked the Dealer. He was clueless. Asked service manager, same reaction. It wasn't until we opened the door and read what it said on door post.
No more surprised than me. Ha Almost as surprised as not being able to choose rear axel ratio. Ration changes with tire size.
Go figure. Can you tell Im 73 years old and bought a lot of trucks. LEARNED A LONG TIME AGO that 3:55 s weren't enough 3:73 s worked and 4:10 we just too much. but I'm a retired embalmer, what do I know
OK
weird, my 22 AT4 gasser w/20" conventional towing = #14,500. Hard to believe at duramax has a lower trailering capacity.
That is interesting. Is the Payload changed as well?
I just built a 23 at4 duramax with the18" mud tires. Screenshot shows it will lower trailering capacity.
2nd screenshot shows that the gvwr is the same as mine, so depending on options the payload will be close to the same.
