Bondvillain83
Anyone have a good recommendation on which brand of traction bars to purchase for my 2023 3.0L Duramax?
Pardon my ignorance but what type of use would require the addition of traction bars, which in my experience were only required for drag racing?Anyone have a good recommendation on which brand of traction bars to purchase for my 2023 3.0L Duramax?
Gonna have to second this question.Pardon my ignorance but what type of use would require the addition of traction bars, which in my experience were only required for drag racing?![]()
LOVE Summit Racing products! Was hoping for someone to challenge them with a better product. At the moment, the guys at BD Diesel look like they are spot on. See my video below.Have you tried these guys? Summit Racing
Awesome feedback! Much appreciated. I think at a cost of $900+ ill look at other more reasonable upgrades before traction bars. What would you recommend be my first upgrade? I am hearing that a Banks cold air intake is what a lot of owners are looking at as one of their top 5 upgrades. Im also hearing don't do anything, as the stock LM2 and LZ0 engines are pretty solid already.Thanks for the video, after watching it, my opinion is that traction bars are not required for any GM diesel for normal driving and up to and including maximum towing. The LZO produces 495 lb ft. of torque and that is not near enough torque to produce abnormal axle wrap. My definition of abnormal axle wrap is when you hear banging because the diff has wrapped or unwrapped past the allowable range of the U jts.
I used to tow a 40' toyhauler with my LMM Dually with Banks Tune and it did not require any additional axle support. I know several Hot Shot drivers that tow in the oilfield for a living with Ford, Dodge and Chev towing triple tandem trailers off road and chained up in some cases and none have ever required torsion bars.
The only time one might consider the installation of these is if you encounter severe wheel hop, as you might get while chained up but not in the majority of driving situations. Bottom line as the owner of the truck you purchase and install whatever you feel is necessary.JMO
Thanks!!!Nice to know, thanks. My 2 cents- I have owned a number of Duramax Diesels (all were 2500HD), I routinely loaded 15 rounds bales at about 1200 each plus the gooseneck, never had a problem. I would haul, full size backhoe and tractors and such. I was always worried about stopping my load even with trailer brakes. Regardless, good luck in your search and keep us posted. All here to gain info!
