Towing Interface
OffPiste79
RI
Is anyone else experiencing problems with small trailers with LED lights? My truck is constantly reporting faulty lights that are no bad as well as trailer disconnection notices. I have tried multiple plug adapters but think the logic the truck uses to identify the lights, which I assume is resistance based, is too sensitive for small LED light packages??
I pull a 4K# , 22 footer and have no issues to date.
What do you mean “adapters”, dont you have both 4 and 7 pin bumper installed connectors ?
Try this : build a good solid gnd jumper and and connect to a solid , clean to bare metal, trailer frame connection and the other end to a clean bolt head on the truck frame.
Mine does the same with a small tailer. I get lights not working. I flash or brake and it goes away.. till next time
My truck does not have the 4-pin connector. Just the round 7 pin and two small round for cameras.
Just as mine does 🤦‍♂️. Not thinking , me. I should have been more aware as I use one of the camera inputs with my camper.
Even though, it sounds like a gnd problem to me try running a solid supplemental gnd to get arround the pin and the ball/coupler .
just a note : you a boarder, Telemarker or OffPiest with your truck?
As weird as it sounds, mechanic at the dealership where I purchased, said to make sure the vehicle was OFF before plugging the trailer in. Have towed prolly 5-7 times since and well, by doing as the mech advised, haven’t had the above issues since.
