Sudden spike in fuel consumption
Catman
New Hampshire
Anyone heard of sudden spikes in fuel consumption?
2023 AT4 Duramax, 3,800 miles. Up until yesterday I had been getting spectacular fuel consumption numbers...good ones...with a max mpg of 35.7mpg; averaging about 28 tank to tank and on interstates, 30 was common if not better. I don't push the speed or acceleration. As of yesterday, all that dropped to 20mpg including on the interstate for a half hour drive, worse than I'd ever seen even short tripping or in town.
Only change had been body work due to some person sideswiping a rock w my truck; truck was INOP for 8 weeks, with zero frame or mechanical issues.
I had thought regen, but online comments from expert diesel persons is that with the LZ0, it is invisible. However, it is accomplished per John Barta of GM, by leaving the exhaust valve open slightly longer to deliver hot gasses to the SCRF, thus burning off any particulates. As I understand it the engine has no particulate filter per se, it uses the SCRF. And...thats about all I know.
I have lots of experience with marine diesels including 4 cyl and 6 cyl 12 liter John Deeres, which of course don't have this stuff on them.
The regen isn’t invisible, it does use more fuel when it’s happening. I suspect you had a full regen causing your mileage to drop. Check your “this trip” mileage next time you drive, see if it increases and climbs, especially when coasting.
Thanks. That's my initial Dx (diagnosis) and I'm betting it's accurate.
You can always get a banks iDash to show you the state of the DPF and when regen is active, I’m glad I got one as it demystifies a lot of what the truck is doing.
Tnx. May do that. Probably was Regen although it took 50+ miles to do it. Today got 40 mpg@45 mph on a state hiway and 33+ round trip/20 miles. Amazing with these tires and a fairly beefy truck. Diesel gets a bad rap in the US.
