Shorty antenna Recommendations ??
Lasllc
Very Western ID
What I bought. Works good for all.
So.... I'm trying to swap out antennas to a shorty and attempting to remove my stock one, it just spins! Not sure if the base is loose and I need to get in there and secure the base and then unscrew the antenna? Any insight would be helpful.
Got it! Apparently my patience when it's 8 degrees out is pretty low, I just needed to keep spinning it off as it was a tight fit! One pass in the car wash and the stock was already bent!
Q: Did anyone have to remove the antenna post for the new antenna to screw onto it? The one I bought on Amazon came with a variety of posts to go with it, and it's too small to screw onto the factory post. I can't figure out how to remove the current threaded post, though.
Honestly, I'd just return it and get any of the many others that fit. Not worth the trouble.
Is there such thing as an antenna delete and a plug to cover the hole?
