Sd card
If you are talking the Nav Card, it kind of varies. The part number for my 2020 AT4 is 86775533.
I bought it from a used dealer and the SD card was locked up (stuck in another vehicle). Once they are stuck in they are locked to that vin.
When you program it (stick it in the SD slot), make sure you cars power is completely off. I left the power off, key out of the car and door open for about 10 minutes. After that I stuck the SD card in and started the engine. You will then follow the prompts. Just a few questions.
You can google the part number and it find them online. Mine was about $250. The dealer wanted $550 and then two hours of programing (which took 10 minutes max.
