RSI Smart Cap
I've read that it doesn't work with the rearview camera.
Here are some good installation photos on a TrailBoss:
I have one and can confirm the third brake light camera is blocked. I’ve picked up an extension wire for the camera and a Yukon rear camera. I’ve started working on a 3D printed bracket to go inside the rear window of the cap and it’ll use the screws for the third brake light.
Here's mine...just installed a couple of weeks ago. Ditto to what @AnonymousM00SE said about the rear view mirror camera. I never used it anyway.
Do the top rails or intake scoop sit higher than any part of the truck roof, like the sharkfin antenna? My new 3500 will clear my 82.5" garage (7' minus seal strip trim) with about 2" clearance. I know the cap I have on my f150 sits at the roofline/below the sharkfin, but wasn't sure if that was consistent across models
They sit just as high as the antenna on the roof of the cab. I went out and measured to be sure. Great question!
Tim
My smart cap should be delivered any day. I need to know how many inches above the cab the topper vent is. If it won’t fit in the parking ramp at work (7’), I’ll have to return it.
Stock height you will be fine. I have a rack on mine and it sticks a good bit above the vent. I went under 7’ 2”
I would be interested in seeing some of your pictures once you complete it. I’ve searching for options with no luck what we really need it a replacement 3rd break light that has t to e camera in it made by rsi
Does anyone have an RSI SMART Cap, a Decked system, and an intermediate gunner kennel? I am trying to see if there is enough space for the kennel and the Decked system. The measurements say there should be an inch but I would like to see if anyone has it already.
Been slow progress but my draft versions worked ok but the glass gets dirty fast so it was kinda useless.
I’m working on replacing the stock third brake light with either an aftermarket or a new housing with the the Tahoe cam and red leds for lights
