Rear block question
poopster
Western New York
Rear block question
2022 AT4 w/factory lift and I added the Ready Lift leveling kit and the Bilstein 5100 adjustable shocks in the front but now the front sits 1” higher than the rear. I’m installing the Bilstein 5100 shocks in the rear which won’t give me anymore height, so I’m thinking I need to replace the blocks in the rear but I’m not sure what to do. Do I replace the entire block or just add a 1” block on top of the OEM block? All I want is 1"-1.25".
I’d like to know what I need before I take it apart.
Any suggestions or help would be greatly appreciated.
Rear block question
Got instructions on U-tube and bought a 2" block on e-bay. ETA, 3-5 days. So, I'm good to go.
Rear block question
Did you set the bilsteins to a higher setting or leave them at 0?
Set the front shocks for maximum lift.
Wow! I’m looking at the bilsteins and have the ready lift 2” kit. Have you had any issues with using the ready lift and the bilsteins? Reason I ask is that some were concerned about axle angle/stress and all that jazz.
I used the Ready Lift w/upper control arms, and it worked out very well.
I've only just installed this setup so I can't say anything about reliability.
It would make sense that your font end is now higher than the rear if you used the highest circlip setting on the Bilstein(1.1") in conjunction with the 1.75" level, so you essentially lifted the front 2.75" over factory 2". The UCA are probably fine but you'd want to check your CV axles as I imagine they would be at a pretty high angle with that amount of lift and no diff drop.
You should have got the 2 inch kit and used the stock shock setting.
Your axles definitely aren’t happy.
The stock block on the rear is already 2 inches.
You are correct, it is a 2" block already in there. I don't know why I thought the block was 1" but obviously the 2" block I ordered isn't going to work, I need a 3" block to level the truck. I did install the 1.75 Ready Lift with upper control arms, so my axle is indeed happy.
Now I realize that I should have set the front shocks lower but the reason I put those shocks in was I was rubbing badly with the 35" tires, even after trimming and could have still rubbed with the shocks set on lowest setting.
So, now I have to order the 3" blocks. I was going to wait on installing the new rear shocks until I had the new blocks but have changed my mind and will install them tomorrow.
Pictures to follow.
