thewholetruth
Hi all,
Planning to put a plow on a 2024 2500 AT4 that I'm about to order with the duramax. I am adding the snow plow prep package but it does not seem to auto add either the dual alternator or the auxiliary battery. Here are my questions:
Do these trucks come with a single battery with the diesel?
On my F250 gasser with a single battery every once in a while the plow will draw enough current to reset the truck dash display / electronics
Should I consider adding the dual alternator and auxiliary battery, or what would be the main use case for these adds?
With the hood scoop being [I believe] functional, is the plow going to create any turbo cooling or airflow issues? I can't imagine it will since they allow you to add the snowplow prep package? I know this is an issue on the current Tundras and upcoming Ram hurricanes, but those are 1/2 ton trucks.
Also is it possible to order aux switches from the factory on the AT4?
Thank you.
Thank you.
