Puddle Lights.
Is there a way to make make them stay on when I hit the unlock button? Mine come on and go off quickly.
I think if you go into settings, then the vehicle tab on the upper right, then select lighting, and I believe its exterior lighting, you can set the duration of how long the lights stay on. I have it set at 30 seconds, and the puddle lights illuminate with the head and tail lamps for that time when unlocked. You might be set to "off" for them to just flicker when unlocking. Hope this helps.
Thanks. I’ve done that. I don’t see where they can be turned off either. Seems to be a common problem on some refreshed models.
You need to make appointment with dealership. It is a programming issue. It my dealer about a hour to fix.
