Your pic shows a tire size of 285/85/20 which is 39.1" in diameter vs my stock 20" which are 32.5" in diameter so a difference of 6.6" or 3.3" in radius so probably the reason for the spacer and the lift.
The stock cv jts. may be outside their design range as you mention and you may have to chat with the lift folks to see what their recommendation is.
Your speedometer reading at 65 mph stock setting would actually be running 78.1 mph.
I have no experience with lifted or levelled kits and am happy to stay at stock ride height.![]()
Yep there’s that “leveling” kit spacer.I have this same spacer on mine which I also bought used about 2 months ago. No other spacers, truck sits level and rides great. I’ve been wondering this for a while if this was factory too. View attachment 3895View attachment 3896
Be careful and talk to some of the guys here that know about this stuff because I’ve seen failed stock control arms when guys use some of these level kits. Not trying to alarm you but since it’s not factory you take on any risk and if something in that front suspension breaks warranty isn’t going to cover it due to that modification which changes angles and puts different stresses on parts.
