OIL LEAK
501AT4
ARKANSAS
I just got my 2023 AT4 3.0 back from the dealer with an oil leak. They said it was the crank shaft seal.
This is the second time I've had it in there. The first time was a couple of days after it's 2nd oil change. they said it was the oil filter had a "crack" in it. After taking it home and a few days later, it was still leaking, but not as bad. This time i took it in, they came up with the crank shaft seal. Has anyone else had or seen this? 15.5k miles on it.
I have the LM2, not LZ0 like you, but I have not had a single drop of oil leak on mine. I'm at about 14k miles.
You should still be under warranty. So if they know what it it (crank shaft seal) have them fix it on their dime. No reason to wait an see.
I worded that wrong. I just got it back from being fixed. It did have an oil leak. They fixed it on their dime. (warranty). Thanks for the input. I just hope this was a one time fluke.
Got it. Hopefully it was a one off issue and doesn't come back for you.
My 2021 has 20,000 miles I bought it used with 17,000 miles. I put 3,000 miles on it and it started leaking oil. Took it in they told me it was a rear seal. They've had it for 13 days said parts were on back order gave me a 2015 chevy car to drive and said not to expect it back until after the first of the year. I am not happy but as far as I know there is nothing I can do about it.
