kikotrex
Is anyone else having a hard time finding low sulfur diesel, All I find is the Biodiesel fuel. Does it even matter.
All diesel is low sulfur, whether bio or not.Is anyone else having a hard time finding low sulfur diesel, All I find is the Biodiesel fuel. Does it even matter.
You read it wrong. Manual states up to 20% biodiesel is allowed. I haven't seen a pump over 5% and I'm in the heart of soybean production.I never buy bio-diesel. I believe my duramax owners manual says to not use it.
Maybe you are referring to homemade biodiesel?I never buy bio-diesel. I believe my duramax owners manual says to not use it.
Here is one of many stations that have recently converted to B20 from B5. Not sure around the rest of the country. Here in Southern California you are going to be hard pressed to find any station that has B5 in the near future. This is due to Phillips 66 refineries shutting down in Carson and Wilmington. B20 is much easier and cheaper to produce and a big profit margin for petroleum energy producers.
Gasoline will be business as usual as the refineries that are closing are primarily jet fuel and B5 USLD. All modern consumer pickups with diesel power plants can operate on B20.
I highly recommend running a Raycor 460R or 490R water separator/filter. I used these in all kinds of heavy equipment and commercial vehicles. In a tiny sub 8 liter low torque engine pickup you will never exceed the flow rate on either of the units. B20 carries a lot of moisture (as a byproduct) that the OEM system cannot get rid of (requiring excessive re-gens).
Change the filter every oil change with piece of mind of removing all but the tiniest of contaminates and a lot less water vapor during combustion. This will help raise the exhaust temps, use less DEF, less frequent re-gens and result in a longer lasting DPF.
Yes and that is cheap diesel. B20 is cheaper to produce and is typically .50 to 1.00 cheaper per gallon than the B5. Now you understand why I won't be going with a diesel truck. If CARB and AQMD had their way, they would figure out a way to either get rid of CI engines altogether or have them run on B100.$4.78 a gallon? Holy shit. AND it's more than 20% bio?
How much does CA tax a gallon? NE is .46 a gallon, but our hiways are good.Yes and that is cheap diesel. B20 is cheaper to produce and is typically .50 to 1.00 cheaper per gallon than the B5. Now you understand why I won't be going with a diesel truck. If CARB and AQMD had their way, they would figure out a way to either get rid of CI engines altogether or have them run on B100.
