Fordconvert
Anyone drop to lower gears after lifting and adding wheels and tires. If so what difference did it make for you. I have been considering going to 3.73 in my 2300 AT4
Greaham4wheeldrive must have been looking for views. I assume they are from my state of Oregon unfortunately. What a crap caned google response (to a post from 2023) that had no actual help to the long dated question..WHAT?! upgrading to 35” tires on 2020+ 2500/3500 and your recommending a gear change, LMAO. Going from a stock 34.1 inch tire to a 35 inch tire the dash would read 100mph and the truck would be going 102.6 mph.
Unless the truck is being lifted to fit 40”+ tires and solid steel wheels, there little need for gears. The hd truck is capable of towing 26k lbs+ any day, that’s 70x the load on the drivetrain than wheels and tires.
i am on the fence, mainly because i live in the mountains and drive the passes all the time.Greaham4wheeldrive must have been looking for views. I assume they are from my state of Oregon unfortunately. What a crap caned google response (to a post from 2023) that had no actual help to the long dated question..
With the gasser AT4X I have 3.73 and went from the stock 35” to 37” recently. Drives great especially with the 10 speed. Minimal difference in tires, absolutely no reason for gear change.
A perspective of mine on your situation. The HD is geared for peak torque rpm to cruise 60-70mph(most common Hwy speed limits) . Going from 35” to 37” the speedometer would be 4ish mph slow. Relatively this offset would be appealing to me bc it moves peak tq and mpg rpm to the 64-74mph range. Since 65 and 70mph speed limit is a lot more common around here, the truck would likely get better mpg overall.Greaham4wheeldrive must have been looking for views. I assume they are from my state of Oregon unfortunately. What a crap caned google response (to a post from 2023) that had no actual help to the long dated question..
