Leveling kit
tommy_21
GA
Curious, I have a 2021 stock AT4 with the 20” rims. Considering putting a 1.75” level on the front. Did those 295s rub bad?
They definitely rubbed but it wasn’t that bad, but definitely required trimming or fender modifications for it to clear full turn. I can send you some close up pictures and explain what I did in further detail if you want. Also with the level you probably would have to run wheel spacers to clear the aftermarket upper control arms because my 295s are about 1/8 inch away from the stock ones
Did you end up putting the blocks back on the rear and doing the 1.75” level? I’d love to see how that turns out because I’ll probably be doing the same think. I think you’re certainly right about the spacers.
I haven’t, I think for now I’m going to leave it at least until it’s time for new tires then figure it out then
