Front Seat Backing 2023 AT4X
DeltaRed2
chattanooga, TN
Hello everyone!
Has anyone else had their front seat back plate fall off? driver or passenger side. Mine fell off, nothing is broken at all, but i cannot figure out how to get it back on. It has two metal clips on top which fit into the plastic backing and look like they are supposed to hook into the metal hols on the seat side. But there must be a trick to getting them in there. Suppose i will just have to take it to the dealer.
The way it came off makes sense, i had the seat memory set to lower when the door opens. when the seat lowered, the backing pressed down on an ammo box and it unhooked itself. commical.
Same thing just happened to my 2023 at4x aev. Saw it hanging a bit and tried to fix it and it just came off. 2 metal clips are just hanging there
Hey Robxod, i took mine to the dealer, they also were perplexed on how to get it back. we both finally figured out that we were putting the little U shaped hanger in the plastic upside down from the way it was designed to work. Meaning the U shaped hanger goes into the plastic hanger facing up (like the letter U does when writing) then push the seat backing back into place. it should snap with no problem.
I did it just like you described and it worked like a charm. Thank you DeltaRed2
