Fox 1.5" 2.5 DSC Level & Tire Fitment 35x11.5r17
noiseyears
California
I purchased what I think are all of the necessary suspension/tire/wheel upgrades to my 3.0 25' AT4. I spent months researching, speaking with 4WD shops, BDS, Peak Suspension, etc., and felt very confident in this setup:
  • BDS 1.5" Level Kit w/ Fox 2.5 DSC Front & Rear Shocks (can be manually adjusted higher if needed)
  • KMC 17x8.5 0 Offset Wheels
  • Toyo Open Country AT3 35/11.5r17 Tires (Actual is 34.5 x 11.4)
  • Rough Country Fender Delete Kit
Now that i have all of the parts in my garage, i'm having second thoughts about the tire size. Everything I researched suggested this 'small & narrow' 35 tire would fit after trimming some fender liner, front valence, mud flap delete, etc. I think I'm having second thoughts, partially because there have been so many mixed experiences with folks and what they report "working". What I absolutely want to avoid is rubbing when the wheels are flexed. Once the tires are mounted, I've crossed the 'no return' with the tires. What do you all think? Peak states they fit 315/70r17 with their kit (which is actually a 2"+ front lift), and from what i understand the rub issues mainly come from incorrect offsets and tire width (pushing 12.5" wide tires). Again, i felt very confident in this setup. What do you all think? Go for it, or return the tires and drop to a 305/70r17 or narrower 385/75r17 (reports make it sound like these have rub issues too, again, depending on all of the other variables). Absolute main goal here is to avoid rub when flexing - no rub hitting speed bumps/driveways when turning.
Thanks all.
I plan on 35×12r17 Mickey Thompson Baja Boss ATs. I have leveled with Bilstein 6112's on highest circlip. I'm also going to add a lower strut spacer to get 1 more inch of height and to maintain level after that, I'm going to swap the factory 2" block for a 3" block.
This guy has a video of a unique way to make some room which you may still be able do with your mudflap delete. Maybe this will be helpful. My opinion is: GO FOR IT and make em fit! You most likely won't have any rubbing if you do all that stuff. Have fun!
Unfortunately I can't add any useful information. I'm just here to see what answers you get and complain about how difficult it is to upgrade wheels/tires on a truck for someone that doesn't want to go crazy with suspension upgrades.
Good luck!
Installed.
  • The rear reservoirs were a PITA.
  • I ditched the provided BDS 2.5" block for a 3" block, given the daily weight (GFC Camper & full-size decked system). Sits somewhere between .25"-0.5" rake. My goal was 0.5"-1". We'll see if I need to play with it after everything settles.
  • I still need to install the front Rough Country mud flap delete caps.
  • Ideal amount of poke for my eye.
  • Zero rubbing after light trim of the front valence and prep work for the mud flap delete kit. I used a red-hot razor blade for clean cuts.
Overall, extremely pleased.
Installed.
Looks great! Glad to hear there was no rubbing after your work!
Definitely a happy camper. Also took the time to install the Peak Suspension sway bar relocation blocks and tie-rod reinforcers.
Regarding trimming. I was following this YouTube channel (@NothingButLifts) during my research and thought he did an excellent job of making everything look so clean. I took screenshots of a few of his AT4 builds to lay out my trimming needs.
I did the same RC med flap delete and followed this video, very easy.
