Very similar to why I chose the 6.2I had duramax 6.6L in my last 3 HD trucks and loved the engine. However, I didn't care for the maintenance, fuel filters, def fluid etc.... ( I miss my LBZ) This time around I'm towing MUCH less so I didn't need the HD. I got the 6.2L because, they didn't make it with a 6.3L![]()
Be safeMost of my towing these days is motorcycles, maybe a small tractor, jeeps and hotrods etc... but nothing too heavy. Except.....next week I have to drive to Vermont to pick up our sprinter camper van that's been in the shop since it broke down in July. That thing is a heavy pig, even with my aluminum car hauler only weighing 1900 lbs......once I load that sprinter I'll be over the recommended towing capacity. But it's a 6 hour drive....my trailers got brakes on both axles, and I'm just going to take it easy. I'm sure the 6.2L has the power, it's just the gearing and probably the lift that hurts it's towing capacity?
You should be fine- like you said just slow and easyIt may not be over.....my truck says 8,800 lbs. I know my trailer's 1900 so that leaves me 6900 lbs.....my sprinter weighed about 5500 as a cargo van...with the camper build out.....no idea...but I'm sure it's close.
Same here. I didn't want to worry about the DEF, EGR, etc so I went back to a gasser. Plus, the old LBZ was in the garage every weekend fixing odds and ends.I had duramax 6.6L in my last 3 HD trucks and loved the engine. However, I didn't care for the maintenance, fuel filters, def fluid etc.... ( I miss my LBZ) This time around I'm towing MUCH less so I didn't need the HD. I got the 6.2L because, they didn't make it with a 6.3L![]()
