Josh_O
Hey everyone,
To the point.
Install was simple. I pulled roughly 7 screws, from the forward/lower part of the wheel well liner, to gain access to the factory fogs. Unplugged them, removed the 3 screws holding them in. (T15s)
Foxbeam mount replacements are 3D printed. A couple things. Where the light mounts on the bracket, it could be ⅛" lower and ⅛" moved back. Those are my only gripes.
(Side Note: don't gorilla the mount screws to the bracket. There is no way to adjust them but by hand once installed. Make them tight enough to sit still but loose enough to aim them. There is no tightening them down after install unless you have the hands of a Kebbler Elf)
I plugged the DD harness into the factory harness then into the light, polarity sensitive so test fire once it's plugged in before completing install.
I chose yellow. I love yellow fog lights. I have 2 yellow spot lights under the truck as well. They will probably become ditch lights.
www.diodedynamics.com
Here are some pics. Feel free to ask any questions.
By the way, Foxbeam has mounts for those of you with the rectangle fogs in the bumpers of the newer trucks.
www.foxbeamlighting.com
To the point.
SSC1 LED Fog Light Kit for 2022-2026 GMC Sierra 1500 AT4X
Features Direct replacement for factory GMC Sierra fog lamps. Significantly higher output than stock, with Osram Boost HX 20W LED. SAE-compliant road-legal performance. Plug-and-play, no modification needed. Advanced TIR optics focus light exactly you need it. Engineered and Assembled in USA...
Foxbeam Lighting
Automotive LED lighting for cars and trucks, including headlight, fog light, turn signal, backup, tail, interior, halos, demon eyes, boards, strips, and more!
