I have an 8 channel Infinity amp (same as the JBL that is available/same company) with built in DSP. It is 3 or 4 ohm stable but puts out more watts with 3 ohms, so that is why I did the others. I split the tweeters all on their own channels and door speakers on their own so I had to run all new speaker wire. But that let me adjust every speaker, cross over points, time delay etc. Factory has the a pillar and door speakers and the rear tweeter and door speaker sharing a channel. With the 3 ohm speakers I think the amp is giving 60watts each channel, 4 ohms I think was about 10 less. Factory best I could measure was max about 20 watts out of the Bose and and that was split between tweeter and woofer, so 60 watts RMS for every speaker is a huge difference. I am using all 8 channels on the amp/dsp. I have a separate kicker key amp with built in DSP and anti bass roll off that sends 500watt RMS to my kicker solo 10” under the back seat (dual 2 ohm coils for a 1 ohm load). I did not amp the 3 dash speakers as they produce 90% ish of the sound via factory tunning. I wanted a full 360 surround feel, so I replaced the 3 dash for better sound then tuned my DSP amp to blend all the others at the right level so now you don’t hear the music coming from the dash. In my AT4X I have a center 2.75” in the middle of the dash, same as the 2 corners.
