Dash Camera Recommendation
I just installed a Blackvue 900X Plus 2 Channel Dashcam and have no complaints. I tapped into my passenger fuse block. I used the fuse to the left of the double 50 AMP as my accessory.
Can you show pictures and point out where you ran the cord and stuff?
Look up Dons life on YouTube. I pretty much copied him when it came to running my cables. He has a couple videos on installs of dash cams with his AT4 and Escalade and they mimic one another.
Was searching for dash cam installs for my Sierra and came across this thread, so thanks for the recommendation. However, searching "Dons life" with the space didn't quite turn up what I expected 🤣.
I purchased one off of the GMC accessory website. It appears to be the Thinkware F200 pro model. It has from and rear cameras. I'm sure it was a bit over priced, but I used points to pay for most of it. The main draw was the plug and play harness that connected to the OBD plug. The harness plugs into the factory plug and has a additional OBD plug so you don't need to buy a splitter. It also came with a 32GB memory card. It was $279 on GMC. Best Buy has it for $199 but it does not come with the plug and play harness or the memory card. I'm pleased with it. I just wish the app was a bit more user friendly for downloading videos off of the camera.
Here is the link:
Here is the link:
Did you install yourself or did you have the dealer install it?
