Chains on LT275/65R18's
joegolden
Corona, CA
The zip ties may work so I would try them. The reason they say not to run chains is because of clearance issues and if the rip your fender off they do not want to be liable. Get some winter rated studded snow tires and you probably won't need chains.
Yeah, that is what I thought the reason was. If I was driving more than a couple of times in snow a season I would, but this is for the occasional trip to the mountains. I found some cable ones that will work.
I ran across these, they may be an option for you. I put in your tire size and these came up. so you may have to call to confirm fittment.
I purchased the QC Canada Pathfinder V-Bars for my 2023 AT4. Luckily, I haven't had to use them yet, but I did install them as a test and they seem to fit. I'm not sure about the issue your dealer mentioned regarding tires. Here in Canada, chains are pretty common up north & in the mountainous areas. I plan on never having to use them but I'd rather have them when I need them.
Yup icebreakers because when you need
Yup icebreakers because when you need chains you need chains. When things get that bad I chain up all four and then its like a tractor...
Until you put chains on a tractor! 😁
Is that for clearing your driveways or similar for snow? Perhaps it’s to deal with mud. What do I know 😟
It's both. Have to supplement cattle with hay, when cattle are in fields grazing on corn stalks. Usually before a big winter storm, cause they can't find the corn thrown over the combine in deep snow.
I've found online some tire chains for 295/60 r20 at Murdoch's farm and ranch. The local Murdoch's is 5 or 6 miles from me, so I will go check them out. They were only $130.00 also. Looked pretty good online. Truck chains, not car chains.
Makes sense.
Bringing this back…
I can find anything in the app manual saying not to chain up..
I’ve got an elk trip at the end of the month that can produce bumper deep dumps.
When I was young my light 86 Toyota with chains up front floated everywhere.
My F-150s I chained up maybe 4 times up there.
I had hopes of new rubber before heading out, but that won’t happen.
Anyone seen language saying not to chain up a 1500 at4?
Thanks-
Bringing this back…
Thanks-
