BMC Lighting - HD Fog Light Replacement Tuturial
Kind of figured it was pretty involved.
I picked up the SSC1 LED Fog lights in November and was planning on installing during the Christmas break.
I was trying to figure out if it was possible to install without removing the bumper.
Guess its not possible on the 2500.
Pro tip for 2500s, if you remove the grill, make sure to put some painters tip along the edges of the trim pieces so that when you remove the grill, it doesn't chip the paint.
WOW, that is a lot of work to swap out fog lights. If I am doing that I am installing grill light too.
Exactly, hehe
It was kind of a pain when I took my grill off to put a lighted emblem and 2 LED bars.
I was prepared though, I bought replacement body panel clips for all the clips involved (i broke 3 or 4, of 2 types), and made sure to try to protect the paint as much as possible.
Some of those pieces, when you start to apply force over the bumper, you can see the plastic rub, and flex, so I used painters tape to protect the edges.
