Bilstein 5100/6112 + 1.75 Level
debo4x4
GA
Anyone upgraded to 5100's or 6112 with a level kit? I recently did a Zone 1.75 but did not replace the front stock Rancho's(have already done the rear 5100's) and now I'm somewhat regretting not doing it while the struts were disassembled. Question would be how to set this up if it can be done? Would you set the circlip at lowest setting then still use the preload spacer and top spacer from the kit? Or would you use the highest circlip setting and not use any of the level spacers? Could you set circlip at highest setting and just use the top spacer to gain more than the 1" from the shocks? I also looked at the 6112 coilover's but would still have the same question. Comes down to I need more than the 1" increase with shocks only but know that mixing parts like that can be someone problematic.
