Better riding tires for AT4X
RDUAT4X
RTP, NC
I have a 2024 AT4X. Getting ready to buy a new set of tires.
What have others done with new tires to improve the ride quality? Would be interested in knowing a slightly larger tire (agnostic as to brand) that will ride smoother than the stock Goodyears.
What are others running to smooth the ride a bit? Do K03s ride smoother? What about Nittos? Would appreciate any advice from those who have gone slightly larger with a different tires than the stock Goodyear Wrangler Territory MTs on stock 18" wheels.
May want to consider an all season if you don’t really need an all terrain. All all terrain have a more aggressive lug pattern and will be somewhat rougher than an all season. If you are not really going off road in slick mud you can get a smoother ride. Pros and cons to all tires. I would consider the Goodyears pretty smooth in my opinion vs other all terrain’s. I have run the KO2’s for years, Mickey Thompson Baja, Toyo’s and the Goodyears all in all terrain and would rate the Goodyears on the tame side. I am moving away from the Goodyears to get a 3mountain peak rated tire again. Consider what you really need first if you are really after a smoother ride. Plenty of non all terrain do just fine on gravel and dirt roads.
