AT4 leveling
Big Kahuna
michigan
so I did some reading about leveling my new at4,and I also have a friend who is truck nut, and my concern is that the at4 have 2 inch lift from the factory adding more lift will be hard on the front axels , what is my best option with out upsetting anything to make my truck little more level.
Not on a level kit. Factory ergo’s, with a 2” lift has changed lift kit dynamics. If you shop 4” & 6” lifts. Make note of the component replacements.
The AT4 - and the GM 2" lift kit - includes longer axles, so you should be good on that front. As others have said, UCAs if you go past AT4 height up front.
