Air Intake
Air intake is the process of drawing air into an engine so that fuel can burn properly and produce power. In vehicles that use an internal combustion engine, air is pulled into the engine through an air intake system that usually includes an air filter, intake pipe, and throttle body. The main purpose of this system is to supply clean and sufficient air to mix with fuel before combustion happens.
When the engine runs, it needs the correct mixture of air and fuel to create energy. The air intake system ensures that the air entering the engine is clean by passing it through an air filter that removes dust, dirt, and other particles. Clean air helps the engine run smoothly, improves fuel efficiency, and protects internal engine parts from damage.
A good air intake system can also improve engine performance. When air flows easily and efficiently into the engine, combustion becomes stronger, which can increase power and responsiveness. This is why some vehicles use performance or cold air intake systems to allow cooler and denser air into the engine for better performance.
Air intake is the process of drawing air into an engine so that fuel can burn properly and produce power. In vehicles that use an internal combustion engine, air is pulled into the engine through an air intake system that usually includes an air filter, intake pipe, and throttle body...
Your AI generated response is too new! Old school would've used the word "carburetor" before throttle body! 😁
