33x12.50 ridge grapplers on 22x10 rims
Jarrod82
Illinois
I just recently purchased rims an tires for my 2019 at4. They rub hard on the inner bracket for the mud flaps I removed the flaps and plan on getting mud flap delete kit. My question is what do I need to clear my tires a 2 inch leveling kit ? I've pulled liners back and trimmed front air damn so there's room there. Or do I need a full four inch lift kit. Thanks in advance as onsit here pulling my hair out. N
WOW! Good luck, that is a wide tire and wheel. I bet daily driving is tough right now, even without much flex of off road
Rough country 2 inch level kit removed brackets behind inner fender well zip tied fender liner to pull it back trimmed the front of the inner fender where air damn meets the body. Aligned and rides as smooth as factory no rub no wheel spacers.
33x12.5 on 20x10 -19 offset here with the 2.5 BDS Coilover kit. Had to kill the air dam and tuck the front wheel well liner but didn't need to do anything to the backside of the front wheel well liner. Still have the metal bracket intact. I will say I tried to stuff 35s on it but there's no way with the offset I wanted. You'd have to do 0 or even a positive to fit 35s with only a 2" level/lift. You should be good with a 2" level
I just bought the same size wheels and same tires. I have a 1.75” ready lift with the UCA’s. I have done and took out the bracket and tucked the wheel liner. Have not got them installed yet due to truck being at dealer/shop. May I ask what wheels you have and do you have any pics?
Just purchased 285/65/20 Ridge Grapplers and put them on Fuel Vapor's 20x9 +1. Pretty sure im going to have to do a mud flap delete. 2" Rough Country level already done. Anyone have any issues with that size tire?
It'll be close but since you did the positive offset you may be alright.
On my 2023 I just did 305/55 20 (Falken Wildpeak AT3W) on Fuel Rebel 20x9 +1 offset and didn't have to make any modifications at all. There is a very slight rub on the mudguard at full lock in reverse only (?). Might do the bracket removal trick but feel like it's hardly worth it for now. Super happy with this setup and the way it worked out.
That looks great!! Did you have to use a spacer with that wheel offset to fit the RC caliper covers?
