295/70/18 or 285/70/18 Nitto RGs
Since you are stock offset I’d suggest 285. I have 295 on my truck but my fuel wheels have 5mm of more poke over stock.
Thanks for the reply. I ended up going with the 285s. They look good not quite right though. Could be a little bigger for my eye. Going from the 6 ply to the 10 ply made things bumpier now I am looking at suspension. Such a rabbit hole.
that’s why I chose the 295 they filled the tire well much better. I have the 10 ply as well and haven’t noticed anything about the ride being rough although I have changed my rear shocks to the non at4 size bilstien shocks and went with a 1 inch block instead of a 2.
Got a pic you could share?
Thank you sir! There ain’t much room in between tire and UCA about a pinky’s worth so I’m not sure if they would rub with stock offset but then again 5mm ain’t much difference lol
I got cold feet and stuck with the 285s. This is my first brand new truck and I convinced myself to not just yet start jacking around with bigger tires and leveling etc.. I do want to change out the shocks though. Not wild about the ranchos. I think my next set will be those 295s. They look sharp!
Same here I went from a lifted 03 f250 to this and I did not wanna deal with a lifted truck and the awful ride that comes with it. Especially when towing every weekend. Can’t go wrong with just a simple rear shock change! It made a world of a difference.
