275/65/r20
Gmcsmith
South Carolina
Hi Eveyone,
I’m interested in knowing if anyone has had success with 275/65/r20 tires on factory at4 wheels and stock AT4 suspension. Can anyone tell me if I can run these tires on stock AT4 lift/suspension without any rubbing or trimming?
Need to make a decision asap. Any help is much appreciated!
I have had the Falken Wildpeak A/T3W in 275/60/R20 on my completely stock 2022 AT4 for several months. I have driven the truck on trails with quite a bit of flex and had no rubbing issues.
I have 276/65r20 Firestone Destination XT everything factory. No rubbing or issues. Had them on for an almost a year.
Huge fan of the Toyo Open Country on all my trucks Great mileage and a comfortable ride...and snow rated.
Here are a few more pictures.
I have 285 65 20 Falken Wildpeaks on stock rims and even with a 2” level they rub slightly at full lock.
Hi, just curious do you think you could have gone with 285/65/20 and been OK (no rubbing)?
I’ve read posts of people who have that size and no rub. But I can’t confirm either way. I do have wheel spacers on now, which do cause a rub some times at full lock.
What size spacers? Does it rub on the inside back of mudflap? Have you made any modifications to the mudflap or liner?
Just had a set of LT275/65R20 BFGoodrich A/Ts installed this morning and they fit perfectly without rubbing or need to trim anything. I have not gone off-road yet and flexed the suspension but they appear to have plenty of room. I'm actually installing the Bilstein height adjsutable shocks next week but really just to level the front.
What brand level? Did you put on new UCA? How much clearance do you have from the UCA? Does it rub on the inside back of mudflap? Have you made any modifications to the mudflap or liner?
Can you share pics now that you have the bilstein shocks on? Did you go to the max setting with the shocks (1.1”)? I’m looking to run this same setup.
RC 2” level, Readylift UCAs with 1/2” spacers
Did some light trimming on the front plastic
Left the mudflaps stock
Thanks for the info! I am working on that setup. Getting the level installed tomorrow. Were the spacers required to clear the UCAs or just your preference?
