'25 AT4X AEV Edition front/rear bumper add on lights
wmich06
Muskegon, MI
Are there any aftermarket lights that fit perfectly in the openings on the front and rear AEV bumper? What ones do you recommend, and did you wire the front to your fog light switch and rear to reverse?
There have been a couple of guys here that have posted about the install and products that work, with pictures.
I'll try to find the posts and link, if @pinebaron doesn't beat me to it.
Rear openings are designed for Baja Design Squadron Sport & harness but you'll need the AEV brackets and do your own wiring. There are no direct fitting fronts although I managed to finagle mine in, which was even more challenging with the winch installed.
Which diamondback cover is that? Im thinking about getting the switchback
