2023 LZ0 AT4 electronics, trans, dash goes suddenly goes crazy, check engine, will not shift - truck goes insane
BlackPAAT4
Pennsylvania
First, I love my AT4. I am typing this to help others until GM decides to put out a service bulletin or a recall on the problem. The only reason I put up with this is because I travel a great deal and was able to leave the truck at the dealer for extended periods of time. This is a brand new 2023 1500 AT4, 3.0 Diesel. Ordered in August 2022, received Jan 2023. What happened each time was the craziest thing I ever saw. Usually at a stop sign then accelerate or on a turn at speed suddenly everything in the truck would reset, check engine light, full dash reset, even turned the heater fan on, transmission warnings, on and on and on and on. The first time it happened it scared the hell out of me, left me dead in an intersection in Philadelphia. Horns beeping all around me, and people yelling. Turn it off/on and I can get it to move in a kind of limp mode. I drove it home at 20 MPH, it would only shift to 2nd or 3rd gear. The thing is re-setting all the way.
I get it to the dealer, they call the next day and tell me and I quote "We cant help you. The truck has too many error codes. We reset it and cannot get it to happen again, sorry." They basically ask me to take it home and let them know if it happens again. To make a long story short I had the truck back to the dealer 4 times 1st time, 1 week. 2nd time 2 weeks. 3rd time 3 weeks, 4th time 3 weeks. In between I can only test the truck on the weekends because I travel during the week. They would drive it for hours and hours trying to reproduce the problem, They put a lot of miles on the truck, guessing over 1400. They replaced many, many parts, transmission control module, brake control module, etc. They pulled the truck appart, dash, everything, connected/reconnected as much as they could find. Had a GM local field engineer out several times - tons of recommendations. Still failed after various amounts of time. There is much more to this story, not worth typing.
The problem and the fix:
Bottom line the issue was a wiring harness on the Diesel versions of the AT4, maybe others, that is pulled too tight around the engine block and the alternator bracket. Truck/engine motion wears away the cloth wrap. This happened to me in under 400 miles the first time. Digs into the wires and causes a short. In my case it dug into the white, main communications wire and shorted the communications between all the computers on the truck and it went crazy. The only reason they found it was because they had what I think is a 2023 Denali Diesel with the same issue and through pure dumb luck stumbled across the issue. They then checked mine and found the exact problem. I can understand how it was missed, There is only a pin hole visible and it is buried. To correct the problem they go through the wheel well and because it is a communications wire have a special procedure to repair it.
I am hoping this post helps someone else if they are experiencing strange electrical problems. I was told there are more trucks out there with the same issue. I let them hold onto my truck for an extra few days so GM can come back out, document the problem, examine the repair and re-routing of the wiring harness, then later decide what to do in the future. Pictures below.
@BlackPAAT4 - great write-up! Sorry you had to go through all of this. Is this problem specific to the 3.0L diesel, or are they seeing it with the 6.6L diesel as well?
Good luck!
Sorry you had this but great information for others. It’s crazy how much one hit to the wrong wire can do to a modern vehicle!
@flcmcya, He was showing me the harness through the driver's side wheel well, forward of the engine. The service manager explained several times it was pulled too tight across the alternator bracket. They cut the tie wraps, hold points and re-routed. It was extremely difficult to see.
@RugbyRef, I am not 100% certain. I lean towards this being just the 3.0L, I did not ask that question though. I loved my 2006 6.6 LBZ in the 2500HD Chevy I sold at the same time I ordered the AT4. I no longer needed that large of a truck and my neighbor wanted it so at least I see it once in a while.
@RugbyRef, I am not 100% certain. I lean towards this being just the 3.0L, I did not ask that question though. I loved my 2004 6.6 LBZ in the 2500HD Chevy I sold at the same time I ordered the AT4. I no longer needed that large of a truck and my neighbor wanted it so at least I see it once in a while.
I have a similar issue and was told the same thing. Remembered reading your post and luckily was able to find it this morning. Gonna call the dealership back and see f they will check this area so I "don't have to wait until it happens again" !!!
THANK YOU.
I'll keep posted on updates.
A little more research shows that my truck had this issue twice before I bought it with 1200 miles. When the dealership and salesman told me that the truck "didn't fit the previous owners needs, that they needed something bigger for their trailer" I guess that really meant, "they wanted a truck that didn't go into limp mode". Would have been cool if they would have been honest with me, but I guess I'm expecting too much!
Dropped it off today!
Apparently getting a new Instrument cluster whenever they come off backorder......... we'll see.
I forwarded this thread to my service rep and have it documented.
Got my new screen....seems fine.
.....two days later my buddy with the lZ0 says his screens and outside lights went bonkers and he had to be towed in. Hmmm!
Can’t get mine to do it again to trigger the check engine light and go into limp mode…until that happens the dealership says they can’t fix it.
His ended up being a defective battery......been a few of those as well.
I think it is likely that something with the electronics drained the battery. I just had my battery replaced after 4.5 months. My electronics were messed up yesterday morning, truck wouldn't crank, but the battery had enough juice to run the AC fan, massaging seats, etc. I know this because as the electronics were going haywire, stuff like that was turning on randomly on it's own, even though I had them off.
But the dealer still replaced the battery, they said it was charging real slowly. The culprit to my electronics issue, which bricked my truck, was a stuck OTA download. Now this download did not start to install, it was just stuck at about 50% while downloading in the background. I have no idea why. After the entire afternoon (5+ hours) of the truck at the dealership, they replaced the battery and were able to force the update directly in their shop. Everything working fine now today. Hope this never happens again, it cost me a day of work and lots of hassle.
So mine acted up again on Thursday during a 120 mile tow. Same symptoms as I mentioned above. When it was time to come home CEL was still on, but no Limp Mode. Made it the 120 miles back home and took to dealership (with CEL on this time). Was expecting the worse and a long downtime but they called me about 4 hours later and it was fixed. Talked to the tech when I picked it up…he knew exactly where the problem was when it came in. The above mentioned wiring harness had chaffed. Got it taken care of and hopefully I won’t have any more problems because I LOVE this truck.
Side note: I got it from Laura GMC with 1200 miles on it. I believed the salesman when he said the previous owner traded it in because it didn’t suit his towing needs. The deal was good and the truck was brand new. When I started having problems and my dealership at home dig into it they found that there were 2 issues with the previous overs 1200 miles of ownership just like I had. Based on the information I read Laura GMC was aware of the problem, wasn’t able to fix it, and basically just put it back out on the lot for someone like me to buy.
