2022 Refresh Auto Start/Stop Eliminator Question
ATXHorns
Austin
Trying to install a auto/stop eliminator on my 2022 refresh. The instructions are okay but I don't think is showing all the steps for removing the infotainment screen and control gauge cluster. I took off the (4) screws between the screen and gauge cluster but something is still holding the infotainment/control bezels. Anyone done this and are there any other screws? A guy from the gmaithority forum posted the information below but i don't understand it and couldn't locate any other screws. I want to be careful and not force anything.... I appreciate the help.
"The instructions posted will get you close as they start to repeat. You will need to pop the gauge cluster surround off and remove a screw on the top left of the radio screen. Then there are 2 screws in the top cubby behind the screen to remove (far outer screws). Then pull on the bottom of the screen to pop it out. The plug for the Start/Stop eliminator is on the driver side."
My 2022 AT4 doesn't have auto/stop. Built 12/2021.
Desertdog, just curious- does it still have the switch and just does nothing or what did they put in it’s place?
After Desertdog said his did not have auto stop had to try. Every time since I got truck, as soon as start I would hit the auto stop disable button. So yesterday I did not- button was lit up as if system on. Drove truck over 30 minutes around town, even left it running while wife in two stores- never shutoff. It appears I do not have auto shut stop as well. 👍👍👍
Thanks, mine is right below start button, third switch, with a “A” on it. Now I am just gonna leave it lit
