1500 AT4 Rearview Mirror Adjustment
I don’t have any issues but I’m a tall dark and handsome 6’0”. I’m not sure if all the at4s have it where you can flip the switch under the mirror and it brings up the rear camera while you drive it’s pretty cool feature.
I'm 5'8" on a good day ( with boots) and I've got the seat cranked all the way up (height). Mirrors work fine, and I have them tilt when in reverse so I can see the curbs lol. If you're having to duck down to see.....I'm assuming something's out of whack....maybe try to have them fold in and out or have the dealer check them out?
I knew it would be difficult to describe the issue, so this picture best approximates the problem. My mirror won't tilt up anymore than this. Yes mine does have the flip camera view, but I prefer a mirror.
Does anyone else have a problem adjusting the rearview mirror? Mine seems to top out (tilt up) before I have the ideal view, so I'm having to duck my head down a little to see everything, and I'm a short 5'8". Maybe I'm doing something wrong.
I have exactly the same issue as you on my 2024 AT4, I thought it was only me. I am about 5'10" and have to squat down to see, unless I use the camera mode. I keep my seat in the lowest postion. Have you found anything out to fix this or is it normal?
After 3 years, I guess I've gotten use to it, but I haven't found fix yet. I can kind of force it to the right position but it drops back down later.
A possibility for you is to add seat risers. A bunch of people make them now and depends on the year of your truck.
Or, Since the mirror mount is just glued onto all windshields. You could try to order another mount($6) and glue it on top.
I'm 6'1" and had the same issue with mine years ago, mirror wouldn't go up enough. Finally forced it past the mysterious "stop" and it tilted up a lot more. I brought it back down where I needed and it has stayed.
It does take a good bit of force.
