1 inch level question
speedysierra
USA
Has anyone or does anyone know of just a 1 inch front level kit? I don’t want to go higher than that on my 2020. I haul things from time to time and use my bed for stuff and don’t like the reversed rake look you get when you tow. I am adding some 1.25” wheel spacers after rubbing with 1.5. I have 275/65/20 destination xt tires on stock rims. If the 1.25 still rub then I will look at a level to help me achieve my clearance.
Go with the Bilstein 5100 RHA you will gain approximately 1.1” in the front. While you’re at it replace the rears also with Bilstein 5100. You will be happy with the overall improved ride quality and also achieve front lift. After install I have a 1/2” rear rake, which is fine since I tow a wakeboard boat. Good luck!
I did the same on my 2021 ELEVATION and i put OPEN COUNTRY III 275 65 R20 with no rub . Now I have a new 2023 AT4 and i'm about to do the same except for the rear shocks i'm installing the Bilstein 25-316964 . Now I'm wondering , what size of tire I can get away with without modifications . The tires on the truck now are OPEN COUNTRY III 279 60 R 20 .
Did you do UCA as well?
